Front and rear bulb monitors, rear on the left front on the right
As i suspected the Monitor was at fault, all working now, tidied up the wiring round that as i'd stripped it down. Couldn't understand why when I put the cowling on the slot in the wiper/indicator stacks wouldn't catch the steering wheel, till I got another and one was a little smaller, done that now. Cowling on, steering wheel near on till I drive it to centralize, front mats in as is the dash mat.Last edited by Jeff Turbo; 29th April 2020, 12:56.1958 Ford Consul Convertible. I love this car
Originally posted by Jeff Turbo View PostAlthough it's near completed there is still quite a lot to do
Attach dash side trims and bolt covers---DONE
Position Vin plate--DONE
Get radio fixed
Attach rear view mirror---DONE
Drill holes for door cards-- DONE
Attach door plastic insulation-- DONE
Attach door cards - - DONE
Attach number plates--DONE
Bleed brakes---DONE
Clear boot and put trim in---DONE
Put new jack etc in---DONE
Sort speakers--DONE
Sort tracking
Shake down
MOT
Think thats all of itLast edited by Jeff Turbo; 8th May 2020, 12:30.1958 Ford Consul Convertible. I love this car
Well that was a bummer, bleeding the brakes and leak from a joint I hadn't looked at, made a replacement pipe now so that to fit after i've sorted the intercooler pipes on my MGZTcdti that are leaking oil1958 Ford Consul Convertible. I love this car
After a bit of difficultly bleeding the brakes, had to use gravity method in the end as the air wouldn't come out. Now the car finally moves and stops under its own steam. Paint needs a major clean atm but I not doing that till its finished, I've also attached the drivers door mirror today. On another note, only one fault and red light left to sort on the dash, low washer fluid, happy daysLast edited by Jeff Turbo; 5th May 2020, 14:08.1958 Ford Consul Convertible. I love this car
Last edited by Jeff Turbo; 6th May 2020, 13:45.1958 Ford Consul Convertible. I love this car
Last edited by Jeff Turbo; 7th May 2020, 16:56.1958 Ford Consul Convertible. I love this car
Last edited by Jeff Turbo; 8th May 2020, 13:25.1958 Ford Consul Convertible. I love this car
Even did under the bonnet, though that was a faff. Bonnet wouldn't open so I had to undo the bonnet catch and reposition it, sorted now. Radio isn't plugged in as i'm waiting for it to be repaired. I'm in love now with this car and hopeful of a favourable MOT when my MOT man is back soon.Last edited by Jeff Turbo; 8th May 2020, 12:28.1958 Ford Consul Convertible. I love this car
