The car is back now just in time for the rain but I might get a chance to re-start it before the end of the year
MG Montego efi
In zero degrees the exhaust is now on fully, radio in and working, ash tray back in, all electrics checked and only one bulb now not working, the inner back tail light bulb after changing a couple of dead bulbs and cleaning up some connections. I may have to find another cluster as that's a bit rusty on that connection but see how it goes. I did have a few but threw lots or spares out last year to make room for my wife's Zodiac
Bleeding the brakes again as very little pressure in the system and the front offside caliper has seized solid, calipers are getting non existence now so ordered a re-build kit.
Car starts nice and is very quiet with an exhaust on it, getting closer to completion for an MOT inspection soon1958 Ford Consul Convertible. I love this car
Failed miserably. Couldn't get the dust shield to go in with the piston on. If I put that on the caliper first the piston won't go in it.
Last edited by Jeff Turbo; 15th January 2026, 15:20.1958 Ford Consul Convertible. I love this car
Sussed it, I worked it out. Put seal on the bottom of the piston and leave a little out, put on to the caliper and insert the seal, then push in the piston Happy days
Last edited by Jeff Turbo; 15th January 2026, 15:22.1958 Ford Consul Convertible. I love this car
Last edited by Jeff Turbo; 15th January 2026, 15:24.1958 Ford Consul Convertible. I love this car
And the correct way to do it, leave a little on the end and insert into the grove. Once happy all's in properly push in the piston. Now I have yet another brake issue, the nearside rear brake cylinder won't bleed properly. Pump until it binds and open bleed screw air comes out, then close bleed screw and air back in the pipe, did this for about 30 minutes in the rain and nothing once bled. It's a new cylinder so it has to be the rear flexy pipe as all other bleed ok. I replaced the offside pipe as that burst but didn't do the nearside is didn't look that bad, know doubt that'll snap something when putting the flexy on. All sent to try me as I've run out of rear flexy pipes. Jim at Teesdale has some so will try himLast edited by Jeff Turbo; 17th January 2026, 12:45.1958 Ford Consul Convertible. I love this car
