Million Mile Montego
  • #31
    I've done that job before, what's the special tool John?
    It is just a threaded rod that uses one adaptor to pull the bush inside another adaptor, it is in the second photo, quite a tight fit, but easier than drilling the rubber out & less smelly than burning it out!
    • #32
      Ah I have a set of those and quite cheap to buy. Used that in conjunction with my 12 ton press I recently bought to get a front bearing out of an MGZT 260 knuckle. Took must be 20 ton to move it as the press wasn't enough so added the remover with a large breaker bar. Both together moved it
      • #33
        The press looks very handy, was it expensive? I sometimes use the one at work, but it is a bit big for some jobs.
        • #34
          The press was only £130 and works well, used it a couple of times now. It's all packed back in its box until I need it to remove the front ball joint from my son's Jag
          • #35
            Was this one John
            • #36
              Cheers, very reasonable price, once upon a time that wouldn't get you the pump on its own!
              • #37
                Yeah I know, saw that and thought yep I'm buying that
                • #38
                  Glad I checked the tracking after changing the bushes, that would have scrubbed the tyres off very rapidly!
                  • #39
                    I must get hold of one of these. The set Jeff bought looks good.
                    I have two suspension arms I need to get bushes out of to fit poly ones to. Will save a bit of time
                    • #40
                      Definitely makes it easier, you can improvise with a length of threaded rod and sockets/washers/bits of pipe, good enough if you've only got a couple to do, I realised that I wasn't going to stop changing bushes, so got more tools!
                      • #41
                        I should be able to get hold of a bit of threaded rod and give it a try. Got to be better than trying to cut or burn them. I have ordered poly bushes so hopefully they will last a very long time. The shell of the car will be a long time away before its ready but if I can build up the rear H frame and front cross member? Arms and hubs then it might make me feel im getting somwhere
                        • #42
                          https://www.ebay.co.uk/itm/176690261...Bk9SR5rTjvu3aA
                          https://www.ebay.co.uk/itm/188812588...Bk9SR4iQmfu3aA
                          Not worth it mate, get the proper thing. Top one i used on the wheel bearings on my ZT260. Second one has more in it for smaller bushes etc I bought the second one for my sons ball joints and bushes on his Jag. all worked brilliantly.
                          The press I bought was also a great buy but you could use the other sets instead for bushes, ball joints and bearings on your Montego, saves a lot of work mate
