Originally posted by Jeff Turbo
View Post
Million Mile Montego
Ah I have a set of those and quite cheap to buy. Used that in conjunction with my 12 ton press I recently bought to get a front bearing out of an MGZT 260 knuckle. Took must be 20 ton to move it as the press wasn't enough so added the remover with a large breaker bar. Both together moved itLast edited by Jeff Turbo; 3rd August 2026, 08:55.1958 Ford Consul Convertible. I love this car
- 2 likes
The press was only £130 and works well, used it a couple of times now. It's all packed back in its box until I need it to remove the front ball joint from my son's JagOriginally posted by Doctordiesel77 View PostThe press looks very handy, was it expensive? I sometimes use the one at work, but it is a bit big for some jobs.1958 Ford Consul Convertible. I love this car
Yeah I know, saw that and thought yep I'm buying thatOriginally posted by Doctordiesel77 View PostCheers, very reasonable price, once upon a time that wouldn't get you the pump on its own!1958 Ford Consul Convertible. I love this car
I must get hold of one of these. The set Jeff bought looks good.Originally posted by Doctordiesel77 View Post
It is just a threaded rod that uses one adaptor to pull the bush inside another adaptor, it is in the second photo, quite a tight fit, but easier than drilling the rubber out & less smelly than burning it out!
I have two suspension arms I need to get bushes out of to fit poly ones to. Will save a bit of time
Definitely makes it easier, you can improvise with a length of threaded rod and sockets/washers/bits of pipe, good enough if you've only got a couple to do, I realised that I wasn't going to stop changing bushes, so got more tools!Originally posted by wee_dav View Post
I should be able to get hold of a bit of threaded rod and give it a try. Got to be better than trying to cut or burn them. I have ordered poly bushes so hopefully they will last a very long time. The shell of the car will be a long time away before its ready but if I can build up the rear H frame and front cross member? Arms and hubs then it might make me feel im getting somwhere
https://www.ebay.co.uk/itm/176690261...Bk9SR5rTjvu3aAOriginally posted by wee_dav View PostI should be able to get hold of a bit of threaded rod and give it a try. Got to be better than trying to cut or burn them. I have ordered poly bushes so hopefully they will last a very long time. The shell of the car will be a long time away before its ready but if I can build up the rear H frame and front cross member? Arms and hubs then it might make me feel im getting somwhere
https://www.ebay.co.uk/itm/188812588...Bk9SR4iQmfu3aA
Not worth it mate, get the proper thing. Top one i used on the wheel bearings on my ZT260. Second one has more in it for smaller bushes etc I bought the second one for my sons ball joints and bushes on his Jag. all worked brilliantly.
The press I bought was also a great buy but you could use the other sets instead for bushes, ball joints and bearings on your Montego, saves a lot of work mateLast edited by Jeff Turbo; 9th November 2026, 09:55.1958 Ford Consul Convertible. I love this car
- 2 likes
