Originally posted by Juanmacandel
View Post
Turbo Engine rebuild 20HC85
It‘ s not necessary, Jeff, it was only if you knew it by memory. I will measure it myself and inform you about the results. I will buy 8 units of cam 5821 to try to machining it. Thank you very much for offering, Jeff.Last edited by Juanmacandel; 30th January 2024, 19:08.
Originally posted by Juanmacandel View PostIt‘ s not necessary, Jeff, it was only if you knew it by memory. I will measure it myself and inform you about the results. I will buy 8 units of cam 5821 to try to machining it. Thank you very much for offering, Jeff.1958 Ford Consul Convertible. I love this car
Originally posted by Juanmacandel View PostIt‘ s not necessary, Jeff, it was only if you knew it by memory. I will measure it myself and inform you about the results. I will buy 8 units of cam 5821 to try to machining it. Thank you very much for offering, Jeff.Last edited by Jeff Turbo; 4th February 2024, 11:47.1958 Ford Consul Convertible. I love this car
That's good news! Thanks for sharing the information Jeff. I have 8 new valve guides but the inside diameter is narrower than the diameter of the inlet valves.
The inner diameter of CAM5821 is 7.30 mm.
The diameter of the inlet valve is 7.41 mm.
The diameter of the exhaust valve is 7.96 mm.
The shop manual says the intake valve guide tolerance is between 7.45mm and 7.46mm, but I don't know what the tolerance is for the exhaust valve guide.
Does anyone know what the tolerance is for the exhaust valve guides?
Should an 8mm reaming fit with the exhaust valve? The tolerance will be 0.04um
