Three options, but only two that most people will take.
1. SKF explorer 6208 bearings (x2) Available from any bearing supplier for less than a tenner a bearing usually. Other makes are ok too but specifically the explorer bearings from SKF have a marginally higher rating. You want to specify metal cages as they can also come with nylon cages.
2. M208 bearings (x2). These are the same size as above but have more balls in them and consequently a higher load rating. Make sure you install the filling slots the correct way when fitting the bearings. These are a LOT more expensive and so rarely get used. I think the last set I fitted were about £60 per bearing.
The third option requires machining bearings and shims to fit so is beyond most people (including me before you ask!)
