Its cracked in several places Dan due to heat soak - the exhaust turbine wheel was beyond use also. The T34 is water cooled - but I was running it without. Going to water cool it this time as its just lightened my wallet of £1420 so don't want similar problem to reoccur.
Modified MG Maestro Turbo
Hi Peter - your a cosworth man - I bought these so I can plum into the maestro cooling system to turbo. Anything other than that need doing or recommend?
cheers
mike...
Some good photos Peter thanks. If the diameter of the pipes feeding in/out of turbo weren't smaller I would of directly plumed the heater pipes through the turbo. Spot on with using a T piece close to outlet of the water pump - I will do the same.
cheers
mike...
Yes it will Peter.
I've been looking for that high heat resistant orange pipe I can see in your picture - the pipe that feeds water cooling round your turbo. Could you point me in the right direction Peter where to buy it?
cheers
mike...
Try earls performance
http://www.earls.co.uk/earls/index.html
Expensive but used by the professional motorsport industry.
That's great thank's - 'Flame Guard' yes??
Oh I forgot to mention I found reground cams for the O series to wear quickly due to the poor material they are made from plus the profile tends to be a bit pants if left to cam manufacturers. Check the cam regularly for pitting. I got around the problem by having one made from billet to achieve the lift wanted. bit of a expensive luxury though.
I can remember you saying something like that before - and as of that I'm not expecting much. Is there other things in terms of reliability I should do to head - for example exhaust valve retainers and valve springs?
Not really from memory, material choice is important for exhaust valves and sizing (not too big on exhaust). We did use two valve springs per valve. Now I remember the cam buckets limited the computer simulated designed cam profile so larger ones were to be on the next iteration on the head along with further reinforcement. Strength of the cylinder head itself was the biggest headache along with trying to keep the metal bits together under load. We did toy with the idea of digitising the head and recasting new ones.
Thanks for the info guys much appreciated.
I have sent my head away for some porting work to Scholar Engines. I wanted larger inlet valves but unfortunately Scholar weren't able to find ones that would be suitable of the shelf so suggested to make ones. Expensive to do this of course. Is there any other options guys with the valves?
cheers
mike...
