There was no other damage other than the top of the piston being a bit pitted but after a clean up that should be ok, I've replaced the broken value but haven't come across this before. The car has over heated a couple of times due to various coolant issues, mainly my son driving to Chester with out radiator cap which did the car no good at all and blew the head gasket. I skimmed the head and put all back on and the car was running well for about 2 months until this happened, I know the car isn't running lean and he only uses E5 fuel so a bit of head scratching to do before I put the head back together.
MG Montego Turbo goes
Last edited by Jeff Turbo; 15th September 2023, 13:15.1958 Ford Consul Convertible. I love this car
With this car continually having coolant leak problems and driving without a cap I'm adding an alarm. It should just connect up to this expansion tank then hopefully I won't have to do this again. I couldn't find any issue with the exhaust valve or it's setting so I have to assume when Chris ran completely out of water a hairline crack appeared. The problem is again the temperature guage never went over half. With this alarm on it SHOULD cure this issueLast edited by Jeff Turbo; 18th September 2023, 15:00.1958 Ford Consul Convertible. I love this car
Last edited by Jeff Turbo; 20th September 2023, 11:27.1958 Ford Consul Convertible. I love this car
Last edited by Jeff Turbo; 20th September 2023, 10:39.1958 Ford Consul Convertible. I love this car
Last edited by Jeff Turbo; 19th October 2023, 12:19.1958 Ford Consul Convertible. I love this car
Well that's going to put the kybosh on it, heavy rain all day. Oh wellOriginally posted by Doctordiesel77 View PostLooking good, fingers crossed you miss the rain tomorrow!1958 Ford Consul Convertible. I love this car
Oil and filter changed and car now started and running well after putting a couple of gallons of fuel in the tank as it had run out. Tested the low coolant buzzer and that works a treat so will now wire that in, Scuttle panel removed to fix the welding needed under it, front bumper back on, dash removed to find out why the car doesn't de-mist.
Found straight away that the heater ducting to the screen is not there either side, never saw the when we put the dash in many years ago.
Had a look round my spares and nothing found
So WANTED, heater ducting to demist the screen. They both connect from the bottom of the heather to the screen and are black plastic. Wide flute one end and sort of hexangle the other.Last edited by Jeff Turbo; 23rd October 2023, 15:08.1958 Ford Consul Convertible. I love this car
Yes i was surprised how quickly I got what I needed. didn't cost anything either as I'd helped the guy in the pastOriginally posted by Doctordiesel77 View PostThat was quick! I was just going to say I've probably got a pair...1958 Ford Consul Convertible. I love this car
Ducts turned up today so if it's not raining I should be able to fit, wire in the buzzer and possibly put the dash back in1958 Ford Consul Convertible. I love this car
